Re: Farmall H stability??
Posted by bear4work on March 06, 2006 at 16:03:59 from (66.168.40.188):
In Reply to: Farmall H stability?? posted by Guyzoo on March 06, 2006 at 11:08:47:
Well, then don"t use one of those small, ancient chains. Use a good, strong chain and don"t pull the crap out of it. If its one of those maple stumps with the sub-root system under the main roots, leave it!! I"ve been clearing land and pullin stumps for 25 years!! I don"t mean to be a know-it-all, but as long as your safe, you can do it. If you do something dumb, like not make the chain be even, then you are gonna get hurt. And as Pa always sez "make sure there is someone else around so if somethin does happen, you have help".
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
