Re: Farmall H stability??
Posted by riverbend on March 06, 2006 at 16:56:45 from (208.160.33.95):
In Reply to: Farmall H stability?? posted by Guyzoo on March 06, 2006 at 11:08:47:
Having asked the same question about stability, I did not get much hard and fast information. For side hills, I like to keep the top of the hood inside the front tire.
There is a tractor roll-over webpage from the Univ of NC (if I remember correctly). It was worth reading. The gist of it is that you have to keep the tractor's center of gravity in between all the wheels. When you are pulling, the center of gravity can shift back too far if you have enough power and traction.
I guess you already know about tractors, chains, and stumps...
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
