Re: Farmall H stability??
Posted by Dellbertt on March 06, 2006 at 18:11:12 from (204.39.210.222):
In Reply to: Farmall H stability?? posted by Guyzoo on March 06, 2006 at 11:08:47:
I totally agree with Nat2.
I have been pulling small stumps with an H for a long long time without one incident.
LEAVE THE STUMP 4 FOOT AND BEND IT OVER.
NEVER YANK A LOOSE CHAIN. Always tighten the chain first and then if you want to rock it a little do it with small pressures on the clutch.
ALWAYS HAVE THE TRACTOR LEVEL OR POINTING STRAIGHT DOWN A GRADE. NEVER SIDE OR UP GRADE.
TRY TO PULL WHEN GROUND IS SOFT.
DONT GET STUCK ON STUPID. If you see that the stump is just not going to come out, move on, let it be, or get the shovel out and start diggin.
Dont think Im stupid enough not to realize that a small dozer would be nice to have. But an H is a great puller for small stumps.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
