Re: Magneto success!
Posted by Don Mountain on March 08, 2006 at 05:52:19 from (206.72.59.161):
In Reply to: Re: Magneto success! posted by MagMan on March 07, 2006 at 19:10:58:
My Super C that I put the Magneto on was running and used a lot up until I borrowed the battery ignition off of it to get the M running. And that reminds me, I think the Super C is about due for all the oil changes. In the hydraulics, air cleaner, engine, rear end/transmission, and all the gear cases. And new tires. And new paint job. And greasing/oiling. And yes, I did use the roofing cement to glue the coil core back in. It was pretty tight as it was also. But its glued in tight now.
Don Mountain
