Re: H compression readings
Posted by Janicholson on March 08, 2006 at 14:55:25 from (66.173.50.72):
In Reply to: H compression readings posted by sgtbull on March 08, 2006 at 11:37:44:
As low as that is, I'm going to say what you probably know.
Make sure the battery is fully charged(maybe even on boost when doing the cranking.
Have all the plugs out, not just one.
Make sure the choke and throttle are both wide open.
Test another gauge, or that gauge against a known pressure.
Good luck,
JimN
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
