H compression readings
Posted by sgtbull on March 08, 2006 at 11:37:44 from (65.73.245.246):
Can anyone definitively tell me what the compression readings should be on an "H"? Its reading a miserable 57 lbs +_ 2 on all cylinders. Yeah, it smokes and fouls plugs... I squirted in some heavy oil and checked again.. only came up 2 or 3 lbs.. guessing i've got bad valves/guides. It was originallly an all fuel tractor, but has had the engine replaced. I haven't cracked it open yet and don't know exactly what's in there. I would guess there are different specs for allfuel vs gasoline. If anyone has both, I'd sure like to have the info. Thanks.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
