Re: hydraulic pickup screen 300u
Posted by Dellbertt on March 09, 2006 at 06:45:18 from (204.39.209.53):
In Reply to: hydraulic pickup screen 300u posted by Al Hoines on March 08, 2006 at 18:43:51:
The trans/differential holds 28qt. Not the hydraulic system.
The amount of fluid in your hydraulic system depends on your system.
There is a DIPSTICK in the filler hole plug in the hydro resevoir under the seat. Use it.
If I remember right there is only about 4-6qt in the resevoir. You may have your system flooded.
Good Luck
PS. If your dipstick is missing make your own out of a clean bolt or wire(make sure it is plenty long enough not to drop into resevoir). Using your handmade dipstick fill the resevoir about half full.
