Re: super a pto ?
Posted by Haas on March 09, 2006 at 18:38:17 from (12.65.66.248):
In Reply to: super a pto ? posted by banjo on March 09, 2006 at 11:02:11:
I can answer part of your questions. If you don't have the belt pulley, you don't really need the O ring. The gasket under the cover should be sufficient. If you have a belt pulley setup, then the O ring is needed, because that is the seal to keep oil from leaking out. You don't use a gasket with the belt pulley assembly, instead there are shims to adjust the gear lash. You can get the O ring and the gasket for the cover from an IH dealer. I've had these off before, but I don't recall how the gasket and the oil holes work out.
