Re: Got my new gas caps
Posted by Brian Schmidt on March 09, 2006 at 18:38:22 from (12.206.45.107):
In Reply to: Got my new gas caps posted by HAS on March 08, 2006 at 20:16:47:
Checked out the online form that someone here listed. Did you guys see the note in the middle of the page?
Note:
After 5/31/2007 you will be able to purchase a replacement gas cap from your local CASE IH® parts distributor.
You think they are finally going to stop giving them away????
