Re: H rocker arms... please explain 2 different st
Posted by Dave Slater on March 10, 2006 at 11:51:51 from (205.188.116.133):
In Reply to: H rocker arms... please explain 2 different styles posted by arod on March 10, 2006 at 10:19:45:
They made forged or cast arms on H and then went to what they called welded type made out of steel and was used on H, SH through 350 also. If you have arms removed from shaft theres 4 different 2 each.
You would need to put them on shaft so they line up with valve and push rod when installed on head.
