Re: H fan belt
Posted by jayw on March 10, 2006 at 15:12:40 from (152.163.100.65):
In Reply to: H fan belt posted by Guyzoo on March 10, 2006 at 07:52:19:
Guy
There is a easy way too get them loose a millwright taught me this years ago and it works 99 percent of the time. First take the set screw out and place some penetrating oil on the threads and start the tractor and let it run for about ten minutes . Turn the engine off and it will be loose the belt friction will work it loose make sure you take the set screw out so it wont sling thru the radiator. Give it a try youll be suprised.
