Re: Correct way to hold down suitcase weights?
Posted by the tractor vet on March 12, 2006 at 14:12:17 from (66.202.111.172):
In Reply to: Correct way to hold down suitcase weights? posted by jd jim a on March 12, 2006 at 14:05:44:
each had a hole thru the bottom on and angel that you would tighten up aganist the bottom of the weight bracket , then on the later ones the had a l shaped slot thru the weight that a pice of angel iron went thru and it bolted to the weight bracket .
