Re: tractor vet more advice on the 65 Loadstar 160
Posted by Janicholson on March 13, 2006 at 06:26:07 from (199.17.6.175):
In Reply to: tractor vet more advice on the 65 Loadstar 1600 IH posted by railhead on March 12, 2006 at 18:59:44:
TV is correct!
I would ad that air in the lines always feels mushy, even if there is brake happening after pumping. If after pumping, and holding, the pedal feels stiff, then there is little air in the system. It can take what seems to be a massive amount of bleeding to get the air out. Use a rubber hose from the bleeder into a jar with the end of the hose submerged in BF.
Then pump till new fluid comes out (filling the res as needed to prevent pumping in more air)
I hope this helps
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
