Re: Farmall Cub belly mower removal
Posted by billde on March 13, 2006 at 14:17:53 from (66.249.53.208):
In Reply to: Farmall Cub belly mower removal posted by Jesse on March 13, 2006 at 13:20:30:
If it is a taper lock there should be holes in the pulley that are tapped, and clearanced holes. the bolts you removed should have been in the clearanced holes. Screw the bolts into the threaded holes this will force the taper apart and release the hub from the shaft.
