Re: How much paint
Posted by old on March 14, 2006 at 18:21:53 from (207.69.138.141):
In Reply to: How much paint posted by Andrew Betzner on March 14, 2006 at 16:48:29:
N oset standard on that one. Depends on the brand of the paint. How thin you make it , how many coats you put on. How humid it is yes that does some thing to it. Even if you use hardner or you don't. Can be as little as a gallion or up to 5 gallions depending on how many coats etc.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
