Re: How much paint
Posted by Plain and simple on March 14, 2006 at 22:57:23 from (72.81.8.145):
In Reply to: How much paint posted by Andrew Betzner on March 14, 2006 at 16:48:29:
You're most likely going to use more than a gallon and less than two. Plus thinner and hardener.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
