Re: How much paint
Posted by Nat 2 on March 15, 2006 at 06:23:12 from (64.80.108.52):
In Reply to: Re: How much paint posted by Brian Schmidt on March 14, 2006 at 17:25:31:
Well Brian, that's how they did it at the factory... Save for the hood panels, ignition, rims and tires, the tractor was painted COMPLETELY assembled, all at once.
Those tractors at auctions are painted with ZERO prep work. You're lucky if they hose the tractor off before they start slapping paint on it. It's not because they were painted assembled. It's because it was a crappy paint job meant to cover up some other major flaw.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
