Re: engine timing gears for 300 International
Posted by Dellbertt on March 15, 2006 at 14:53:06 from (204.39.208.219):
In Reply to: engine timing gears for 300 International posted by biggerred on March 15, 2006 at 11:09:11:
are you talking about the two pumping gears inside the pump. Is your pump cast or aluminum.
