Re: H engine specs
Posted by P Backus on March 16, 2006 at 08:54:00 from (69.128.33.188):
In Reply to: H engine specs posted by sgtbull on March 16, 2006 at 04:44:26:
The thing is that it isn"t worn evenly to the 3.445 diameter. If
you check with a bore gauge, it will probably show that it is worn
egg shaped and different from the top to the bottom. Doing it
right is best, but if you want to do it on the cheap, just putting a
S&P kit in can"t be that expensive. Are they maybe $6-700? I
don"t think that will make that much of a difference in the house
fund, will it? If you"ve taken it apart yourself, you can put the kit
in yourself.
Paul
