Re: Farmall H 12 Volt Conversion.
Posted by Bob on March 16, 2006 at 09:47:27 from (64.21.249.40):
In Reply to: Re: Farmall H 12 Volt Conversion. posted by CHRISCO on March 16, 2006 at 09:13:58:
WRONG!
The most common "4-wire" auto supply starter switch is commonly known as the "Ford fender-mount type".
If this is what you have, "S" is START, and "I" means "ignition resistor bypass".
If you are NOT using a system to bypass the ignition resistor (if used) during cranking, simply connet the "start" pushbutton to the solenoid's "S" terminal, and IGNORE the solenoid's "I" terminal.
