Re: Seat Spring
Posted by Wayne Swenson on March 20, 2006 at 12:38:34 from (66.228.250.33):
In Reply to: Seat Spring posted by Andrew Z on March 20, 2006 at 10:22:52:
Look for an original spring with 4 notches cut into the top of the spring usually within the last 2" of the spring end. Fewer notches = less strength.
