Re: COIL S. M. 12 VOLT
Posted by John T on March 20, 2006 at 13:50:19 from (66.244.90.98):
In Reply to: COIL S. M. 12 VOLT posted by BUCK.E on March 20, 2006 at 13:13:20:
Buck, I agree with Bob. I always tell people if a coil runs so hot you cant stand to keep your hand on it, it could be a bad coil or else its a 6 volt coil on a converted to 12 volt tractor. If the coil hasnt been damaged??? its probably cheaper to buy in in line series voltage dropping (12 to 6) Ballast Resistor to cure the problem versus a new full 12 volt rated (some call internally ballasted) coil. Similar, if the points are switching excess current both them and the condensor will have a shortened life.
Good Luck, John T
Today's Featured Article - On the Road with Dave Gohl: Auction Musings - by Dave Gohl. I was thinking the other day about all the auctions I've been to in the last few years. There've been many. Some have been very good, some have been well, disappointing to say the least. But no matter how good or bad auctions may be, we always seem to stay until the item we've come for or are interested in is on the block. I've been to some auctions near and far. I think the furthest has been the Two Cylinder 7 in the Amana Colonies last year. Lots of stuff, lots of people. I've also atten ... [Read Article]
