COIL S. M. 12 VOLT
Posted by BUCK.E on March 20, 2006 at 13:13:20 from (152.163.100.65):
AFTER RUNING MY SUPER M ABOUT 2 MIN. I HAPPENED TO TOUCH THE COIL .IT WAS TOO HOT TO HOLD ON TO. IS THIS NORMAL? THINK ITS A 12 VOLT BUT MAYBY NOT.NO CUTDOWN FROM 12 TO 6 VOLT. COULD THIS BE CAUSE? POINTS ARE TRANSFERING METAL AND MOTOR NOT RUNING SO GOOD. HAVE ALL TUNE UP PARTS TO INSTALL. ON LAST MAINTIANCE JOB, I TOOK DIST., INCLUDING CAST EXTENSIN TO CAM GEAR OFF AS ONE UNIT. I THINK IN PUTTING IT BACK I MISSED GEAR MESH 1 TOOTH BECAUSE TIMING TO RUN GOOD HAS BEEN 1 INCH BEFORE TDC. IS THIS A PROBLEM? THANKS, SORRY FOR SO LONG A TOPIC . BUCK
Today's Featured Article - Dad's 1945 Farmall A - by Bobby Duke Jr.. I am writing about my Dad's 1945 Farmall A. The tractor was purchased in 1945 by his father, Mr. Davis Duke. It was used to farm tobacco from 1945 to 1963 by my grandfather and by my father. ... [Read Article]
