Re: F-20 sleeves/pistons
Posted by Farmallgray on March 20, 2006 at 16:50:56 from (205.188.116.133):
In Reply to: F-20 sleeves/pistons posted by JohnG(TX) on March 20, 2006 at 12:02:07:
I did some research on this a while back. IIRC
JD 3010/4010 gas pistons were the closest in compression height and wrist pin diameter. When they put the 4" S&P set in an F-20, the bottom of the block had to be bored some. The stock sleeves get too thin by just boring them to 4". The JD
sleeves may work as well if the block is bored.
Check with an engine parts supplier like TRW, federal mogul or clevite. They can give you all the dimentions.
