Re: SPARK, BUT NO START
Posted by Jerry/MT on March 20, 2006 at 20:51:57 from (67.72.98.45):
In Reply to: SPARK, BUT NO START posted by jason smith on March 20, 2006 at 19:57:27:
What's your spark look like? It should be a fat, bluish spark when checked at the end of the plug wire with a paper clip in the boot and the paper clip held about a 1/4" from a good ground. If it's yellowish or orangey, you need to find out why by checking out the primary ignition circuit. If you do have a fat bluish spark, the timing has to be right and you have to have fuel to the cylinders. Most distributors can be installed 180 o off since the crankshaft rotates 2 revs per each power stroke. Make sure that when your #1 cylinder is near the top of the compression stroke, the distributor rotor is pointing at the #1 plug. Finally make sure that you have the plugs wires in the right firing order for your engine.
Hope thsi helps.
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
