Re: SPARK, BUT NO START
Posted by Wayne Swenson on March 21, 2006 at 06:16:52 from (24.181.155.110):
In Reply to: SPARK, BUT NO START posted by jason smith on March 20, 2006 at 19:57:27:
First, make sure you have fresh fuel; over 30 days & today"s gas begins to turn sour.
Pull the plugs & squirt some motor oil in each hole and crank the engine to restore compression.
Now, make sure the timing is set correctly. Late timing (too small of a gap or incorrect setting) will act like too rich carburetor problems.
Timing should be set so the points open (set the gap first, .016" for battery ignition) when the timing pointer is between the double marks on the pulley; use the crank or turn the fan by hand (switch off) to locate the marks. With the switch off; use an ohmmeter or self powered test light to verify the point opening instant. This can be done with either #1 or #4 at TDC. Loosen the 2 distributor hold-down cap screws and rotate the body of the distributor in the direction of normal rotor travel until the points are closed (test light is on, ohmmeter reads very low ohms). Now rotate the distributor body backwards until the points JUST open; lock the cap screws and you are good to go.
It is CRITICAL for the points have to be CLEAN and ADJUSTED first.
If you have a 12 volt test light, turn on the switch after locating TDC and follow the same procedure. The light is on with points closed and off when the points open.
Needless to say, points, rotor, cap, & wires have to be in decent shape.
Now start the engine & warm it up in NEUTRAL and BRAKES LOCKED; run at WOT (wide open throttle) and turn the high-speed adjusting screw in & out to find the "sweet spot" where the engine runs its fastest & smoothest. Turn this high-speed screw out an extra 1/2--3/4 turn for power. Idle the engine down & set the idle speed. Now turn the idle mixture screw in to richen, out to lean so the idle is smoothest (this is an AIR adjusting screw so works opposite of the main fuel screw on the bottom of the carb). Re-adjust the idle speed. Perform the carb adjusting procedure another time to be sure all mixtures are correct.
Don"t forget that in the winter your air cleaner may cause richness due to cold oil in the cup or even ice blocking the air passage.
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
