Re: Super M live hyd
Posted by billde on March 21, 2006 at 07:03:27 from (66.249.53.208):
In Reply to: Super M live hyd posted by Jack-Iowa on March 21, 2006 at 06:21:02:
Did you happen to see where his battery was located? Should be under the seat. Unless the hyd pump is located ahead of the distributor it is not live, it would be using the belly pump same as yours. easy conversion to make it live and well worth the money and effort.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
