Re: Alternator Conversion
Posted by T.B.W. on March 21, 2006 at 08:16:55 from (4.248.246.12):
In Reply to: Alternator Conversion posted by Wicksfield on March 21, 2006 at 07:24:32:
I had the same problem. I went to the hardware store and got a larger 1/2 inch pully and took it to a machine shop and had it cut to fit the alternator. Works great and will work at 1/3 throttle.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
