Alternator Conversion
Posted by Wicksfield on March 21, 2006 at 07:24:32 from (66.17.186.2):
I've just converted my M from 6V+grd. to 12V-grd. using the alternator kit purchased on this site. The instructions indicate that it may be necessary to run the tractor at full throttle to excite the regulator. Well, sometimes this works, sometimes it doesn't. When it doesn't work, I momentarily run a jumper from the No.1 terminal over to the Bat. terminal to excite the regulator. This is a pain. What else can I do?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
