Re: Alternator Conversion
Posted by CEB on March 21, 2006 at 08:27:59 from (199.150.177.135):
In Reply to: Alternator Conversion posted by Wicksfield on March 21, 2006 at 07:24:32:
You must have gotten a one wire setup with a "self exciting" alternator. That is the problem that you get with the older low RPM tractors and the one wire setup.
Too bad you already bought the setup. A better way would be just to go to an auto parts store and get a Delco Remy 10 SI car alternator. They are cheap to buy. Just wire it up with a standard three wire setup and not the "self exciting" business. The archives on this site have wiring diagrams for this. Its not that tough to do.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
