Re: Super M live hyd
Posted by Nat 2 on March 21, 2006 at 09:26:59 from (64.80.108.52):
In Reply to: Re: Super M live hyd posted by jack-Iowa on March 21, 2006 at 08:14:09:
If the hydraulics stop when he steps on the clutch, then they aren't being driven by the distributor. Period, end of discussion.
Unless, the engine also stops when he steps on the clutch. If that's the case, he has bigger problems than live or non-live hydraulics.
If this tractor does have the distributor pump, I suspect that it has BOTH the distributor pump AND the belly pump, and your friend is running the loader off the belly pump. He needs to replumb his system.
It was common for farmers to add the live hydraulics to late Ms and early Super Ms that originally came with belly pumps. If it's not plumbed up properly, then it won't work properly.
