Re: Setting Valves
Posted by Jim Allen on March 23, 2006 at 02:53:15 from (209.173.160.22):
In Reply to: Setting Valves posted by Donny on March 23, 2006 at 01:13:34:
Donny, I haven't worked on a great many tractors but I've adjusted the valves on a bazillion cars and trucks. I have an 826 and recently adjusted the valves the way I outline below. I suspect you were out of sequence. so I would either double check yourself or use my method below. Anyway, there is another way to do it. I don't say its better than the way the book says, but I find it less confusing and I'm just plain used to it! Go by the firing order. To make it easier to grasp the concept, on a scrap of paper, draw a circle. Put a big dot in the center. Equally spaced around that circle in a clockwise rotation, write down the firing order of the engine: 153624. Now draw lines connecting the cylinders in the firing order that are directly opposite: 1-6, 5-2, 3-4, making sure that line intersects the dot in the center. The cylinders opposite each other share the same piston position at any point in the engine rotation, but the valves are 180 degrees apart in the firing order. Next, spin the engine around in clockwise rotation, watching the rocker arms until you find two rockers on any cylinder at the overlap point. Overlap is when one rocker is coming back up (exhaust valve closing) and the other is just starting down (intake opening). Move the engine until you find that center point between the one coming up and the other starting down. Next, find the cylinder opposite the one on overlap and adjust the valves because that cylinder is on Top Dead Center and the ignition point where the engine would fire. The lifters are on the base circles of the cam. Say you found #2 on overlap ... you would adjust the valves on #5. Now that you have found which cyinder is on TDC, you know that if you rotate the engine clockwise, #3 will be the next cylinder in the firing order to go to TDC and fire, so watch the rockers on #4 for the overlap point. When you reach it, adjust the vlave on #3. Continue around until you have adjusted the valves on all cylinders. You will make one full engine rotation from the point you started in 60 degree increments. CAUTION: Always turn the engine in the normal rotation (clockwise for most) because some injection pumps can be ruined going backwards a substantial distance. I don't actually know if this is the case with the pump on the 826, hence my caution. I'd prefer not to put my injection shop tech's kids though college needlessly! Also, I made sure the engine kill rod was pulled out and secured that way so that it wouldn't accidentally start. It isn't likely, but I had it happen on a boat engine of mine while I was spinning it over to adjust the valves. I won't argue with anyone whether this is easier or harder than the way in the manual. You turn the engine the same amount, but in shorter distances. I just find it easier to keep it all straight in my head .
Home
| Forums
Today's Featured Article -
Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
