Re: Battery Box - What gauge metal?
Posted by El Toro on March 23, 2006 at 05:17:29 from (64.12.116.65):
In Reply to: Battery Box - What gauge metal? posted by Farmall_Ryan on March 22, 2006 at 20:17:37:
OEM Tractor wants $76.00 for a battery box. Your local sheet metal shop can make you a battery box for a lot less. I would remove the old box and take it along as a sample. They can shear and bend that metal very quickly. I would give the new battery box a coat of acid primer or epoxy primer too. Hal
