Re: IH 454 Diesel Front End Loader?
Posted by the tractor vet on March 23, 2006 at 08:05:07 from (64.179.117.13):
In Reply to: IH 454 Diesel Front End Loader? posted by BelfynJoe In KY on March 23, 2006 at 07:16:23:
Yes it will handel a loader and as for the healthe appite for either well i see that you are not up on diesel operation and all you are doing is knocking the piston rings out of it and it will lead to and earlie engine falure . If you plan on using a diesel in cold weather then it is helpful to have a block heater to warm the engine or keep it in a heated shed . if you have the owners manual i would stongley recomend that you read it from cover to cover and it will explain cold start and allowen the engine and hdy. system warm up before being put to work along with recomend service and correct oils and filters . And throw the either can away.
