Re: Flat rear tire on Farmall A
Posted by old on March 23, 2006 at 08:29:27 from (207.69.139.136):
In Reply to: Flat rear tire on Farmall A posted by Larry Ed on March 23, 2006 at 07:24:06:
On your A there should be 2 ways to remove the wheel/rim. One is to take is loose at the axle the the other is to take it loose at the rim. Should have 4 or 6 bolts holding on the rim part. Air it up then use a jack to get it off the ground just a little remove the tire/rim and either fix it your self or take it in to town. Its easer to tkae it off at the rim because the center weights around 300LBS. Sorry you will not get lucky and have a tubeless tire on it unless some one has spent a lot of money on a custom rim
