Re: Could someone educate me?
Posted by BillyinStoughton on March 23, 2006 at 13:21:00 from (208.50.85.56):
In Reply to: Re: Could someone educate me? posted by chadd on March 23, 2006 at 12:56:27:
I have run a tractor motor on an engine dyno and come up with concrete numbers in the past. Everything is still relative though. I had an overbore kit, 350 cam, and E-12 carb on a C152 and put up 34.2 HP at Engleking's in Rock City, IL...what does that mean?...maybe I pull two bottoms a little bit easier...but the H is still a two bottom tractor.
As far as the fart can Honda argument? It surely makes enough power to perform useful work, it however doesn't employ enough mass or traction to do so. It's the apples to oranges thing. One is going for transportation and MPG, the other for yield to the acre.
Billy
