Re: Fuel Shutoff Valve Clogging
Posted by Maark on March 23, 2006 at 15:29:57 from (206.72.3.225):
In Reply to: Fuel Shutoff Valve Clogging posted by Wicksfield on March 23, 2006 at 12:00:26:
Another way, remove the complete fuel bowl and shutoff assy. Get a short piece of 1/4" copper tubing, drill the inlet just a shade bigger than the pipe and JB weld it in place. About 1" above the bottom of the tank keeps chunks out of the bowl assy.The larger chunks will set on the bottom and not plug your fuel system.
