Re: Flat rear tire on Farmall A
Posted by Dve BN on March 23, 2006 at 17:09:50 from (152.163.100.65):
In Reply to: Re: Flat rear tire on Farmall A posted by Larry Ed on March 23, 2006 at 16:37:06:
I'm not rich but I have my local tire shop come out and do my work. It'll be cheaper in the long run if you do that to. You'll break all 4 bolts that hold the rim to the wheel if they haven't been off recently. 4 new grade 8 square head bolts like the origionals are $100 dollars with nets and washers. You run the risk of ruining the rim which will cost more than $100. Add in the aggrivation and paying to have it done is way cheaper. Dave.
