Re: Will Farmall H pull baler and wagon?
Posted by RN on March 23, 2006 at 20:43:50 from (166.126.218.219):
In Reply to: Will Farmall H pull baler and wagon? posted by Kent M. on March 23, 2006 at 20:35:31:
H was used to pull 14T and wagon on flat ground on home farm, no real problems related to size. IHC 350d with live power handier- about same weight, the live PTO is easier to use. JD 14T is now 'small' baler. RN
