Re: Will Farmall H pull baler and wagon?
Posted by Nat 2 on March 24, 2006 at 05:05:12 from (64.80.108.52):
In Reply to: Will Farmall H pull baler and wagon? posted by Kent M. on March 23, 2006 at 20:35:31:
Flat ground and a small wagon? Yeah, it'll work.
Hilly ground? You might want something bigger.
