Re: Will Farmall H pull baler and wagon?
Posted by BillyinStoughton on March 24, 2006 at 10:09:28 from (208.50.85.56):
In Reply to: Will Farmall H pull baler and wagon? posted by Kent M. on March 23, 2006 at 20:35:31:
I think Old is on the money with that setup. We use an H with a JD 14T and it really is a decent match...but this is Southern Wisconsin, so we are not bucking any hilly situations. The guys pointing you toward the live PTO are definitely sending you in the right direction. Keeping a consistent windrow all the way across a 10 acre field is next to impossible, not to mention the double windrow you will have on the end of the field (in some cases), so the live PTO is always appreciated. The H will do it for you, but once you use that live PTO...you'll only have the H pulling wagons.
Good luck!
