Re: farmall m timing
Posted by Bob on March 24, 2006 at 23:49:55 from (64.21.249.40):
In Reply to: farmall m timing posted by Clint Gabbert on March 24, 2006 at 18:57:43:
If the impulse "clicks" pretty close to #1 TDC, you've got the timing darn close.
When the engine starts, and the impulse "kicks out", the advance will jump to full running timing all at once.
Assuming you have the correct mag (impulse "lag angle" does vary), it is working properly, and firing at close to TDC at cranking, your timing is close enough so that it is NOT the cause of the problems you are having.
Sounds to me like spark plug wires scrambled around, or a valve problem. (Sticky ar burned valve(s).)
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
