Re: Power Unit
Posted by Keith-OR on March 25, 2006 at 18:16:22 from (207.200.116.5):
In Reply to: Power Unit posted by Farmallroy on March 25, 2006 at 17:14:55:
Looks like the one I have that came off a hay bailer. Mine is a 123 CI. the only problem is that you will have to make a plate to cover up the starter hole just under the oil filter. All the info I have been given on this site, is that more than likely it is a 123 as it has a water pump...HTH
Keith & Shawn
