Re: Wiring for F-20 Starter
Posted by Bob M on March 27, 2006 at 06:15:00 from (151.190.254.108):
In Reply to: Wiring for F-20 Starter posted by F-Dean on March 27, 2006 at 05:18:41:
I don't know how "original" F20 electric start wiring was arranged. However from a purely performance standpoint a solenoid mounted directly on the starter and controlled by a remote pushbutton is preferred. Alternatively a remote-actuated mechanical switch mounted on directly the starter (ala M series Farmalls) is good.
Reason: These minimize the length of high-current battery cable runs and thus minimizes voltage drop to the starter.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
