Re: Farmall Cub stalls when warmed up
Posted by old on March 27, 2006 at 09:08:34 from (207.69.137.22):
In Reply to: Farmall Cub stalls when warmed up posted by DickR on March 27, 2006 at 08:12:53:
My guess also is the coil is going bad on you. As far as the govanor start it up and by hand try to open up the gov, does it puch back when you do so. If not you probably have a bad gov also. The throttle is a fuction of the gov. so its also not working right or its hooked up wrong some how which I have seen more then once. Some one may have hooked up the carb/gov rods wrong at some point
