Re: Super c eng. re-build
Posted by Gauger on March 28, 2006 at 10:19:24 from (12.155.240.196):
In Reply to: Super c eng. re-build posted by vally farm on March 27, 2006 at 19:26:03:
Make sure to check the distance that the new sleeves protrude above the deck of the block. .003" to .007" is the spec. Over .007" and coolant WILL leak when the head fails to seat.
