Re: 706 hydralics
Posted by the tractor vet on March 28, 2006 at 17:33:48 from (66.202.111.193):
In Reply to: Re: 706 hydralics posted by butchmo on March 28, 2006 at 17:23:54:
Well if the spool is that bad guess there is no hope for it so guess you will have to find a good used outside valve and as far as putting in a third valve just no room but if you an find the rear line kit then you can stack those lines on top of the lines going to the ft. outlets and have duals on the back along with the ones on the ft. now if you want three outlets on the rear then ya need to get one of those splite outlets that have the electric spliter . Finding a good valve should not be to hard to do . and all you will need is some O/Rings. as for the second rear remote you will need the correct lines and fittings and longer fitting bolts. they are out there ya just have to go shopping.
