Re: 1066 Front Tires
Posted by Allan In NE on March 29, 2006 at 07:28:21 from (148.78.243.26):
In Reply to: Re: 1066 Front Tires posted by Michael Sheik on March 29, 2006 at 07:26:13:
Yep,
One side is close, the other sets out a little. If yours is setting at 3/4" now, it means that they are set in.
Allan
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
