Re: 400 ignition timing
Posted by Brownie 45 on March 31, 2006 at 03:43:09 from (207.177.82.80):
In Reply to: 400 ignition timing posted by SDE on March 31, 2006 at 03:30:32:
Sounds like you have 2 sparkplug wires reversed in the distributor cap. It's a bear to see the ignition wires under the hood with a picker on , but check which wires go to which plug. Don't tear things apart until you check this out. After all, it runs on 2 cylinders.
