Re: 400 ignition timing
Posted by SDE on March 31, 2006 at 15:46:43 from (69.179.7.82):
In Reply to: Re: 400 ignition timing posted by Brownie 45 on March 31, 2006 at 03:43:09:
I had already removed the picker and the wires were in the proper order.(????)I pulled one wire off at a time and the RPM dropped each time. I have been preoccupied with some personal problems and thought that maybe I should spend some quality time in the shed this weekend. Might rain anyway. Thank you SDE
